Bolt on neck... Do I glue the joint?
hummingbird
Post by hummingbird »
So do I apply glue to the M & T joint as well as the bolts or just bolt it on dry? Also should I glue the heel to the body?
Alain
Re: Bolt on neck... Do I glue the joint?
No glue in the motise and tenon joint nor the bolts. Only glue down the fretboard extension.
Tom West
Post by Tom West »
Alain: No glue on the M&T joint. My own personal guitars that have this joint don't even have the fingerboard extension glued. A couple have been like that for at least ten years with no problems except lost of power in the notes of the frets in the extension. I certainly never use those anyway. If you are going to keep the guitar for yourself you can wait a while to see if the action is going to raise a bit.It may save you some work if you have to reset at an early date.You can always glue at a later date.
Tom
If you have 2 bolts you are fine , if it is a Martin neck ,that has 1 bolt and is designed for glue.
+1 what John said.
hummingbird
So do I glue the heel to the body?
Alain
Tom West
Post by Tom West »
Alain: For a normal two bolt M&T joint the only part glued is the fingerboard extension.
Tom
hummingbird
Alain
