Gluing at the intersection of the x-brace.
watergunn
Hi all.
Another newbie question regarding the intersection of the xbraces.
What is the best way to seal the interection at the top of the x-brace once it is glued down?
I have seen where someone used small pieces of wood and titebond to seal that top area.
Thanks for the advice.
ckuo
Re: Gluing at the intersection of the x-brace.
Hi there,
I try to make the joint as tight as possible and then glue on another piece of spruce bracewood using whatever glue I was using before. Has worked out ok so far.
the only thing I can add is that not to make the joint so tight it will deflect. If the joint goes together is just a light rub that is perfect
watergunn
I failed to do anything to the joint before I closed the box. But it is easily accessible though the sound hole.
I it really mandatory that the opening at the top of the intersection be sealed up?
usually they are . A cotton patch will do the job. This helps support the joint
watergunn
Cloth would work. I just wet it with titebond and it should conform to the joint.
Thanks again John.
Thanks again John.
