http://www.kitguitarsforum.com/archives ... 1_0_6_40_C
It's been very slow because I was waffling between spraying with a spray gun or spray cans.
I bought a mini spray gun, then found my compressor had died. By time I got that fixed, I had decided to bail out and do it by cans. John seems to use them and like them, so why make things complicated? The only advantage was that I'd formed a friendship with a guy at a body shop who would hook me up with any paint I wanted. Told me to just pick a car and it's color and he'd match it. But at about $75 for a pint, or was it quart?, whatever, 3 cans of spray paint got me done.
I then used a clear coat recommended by Ken at KMG, that was compatible with the paint, and here's the result before I start level sanding and polishing.
I like the red a lot. It has about 12 clear coats on it, and about 4-5 color coats. Prior to that, I put on about 3 primer coats. Being the first time, I probably have too much paint and primer, but doubt if it will hurt anything. I waited a good amount of time between priming, coating, clear coating.
Thanks for looking,
