All those little tweaks -how do you judge your finished product?
Srick
Post by Srick »
First, I apologize if this is too obvious, but… many of us do an evaluation of a guitar on several levels: its size and form factor, its appearance, its feel and action, and lastly, its sound. I had finished up this build last August:
(It’s in the Blog section)
I was happy that it was finished because there had been so many issues to conquer, but deep down, I wasn’t really happy with the guitar. So during the last couple of weeks and with the benefit of a few months to think about it, I went back in.
  • The neck felt chunky and rough: I used a wax pencil to outline the problem areas and got out the rasp, sandpaper and tru-oil (which as a finish was very easy to repair). I rolled the edges of the fretboard just a bit.
  • The fretboard needed further leveling
  • The nut needed a little more slot filing
  • The saddle needed some more rounding
  • And of course, the finish always needs a touch more here and a polish there. (Note: You really need a good set of magnifiers in your shop.)
Each tweak improved the feel, the action and the sound. Right now, there is one last fret that needs to be ‘kissed’ - there is a barely noticeable buzz, but of course I noticed it.
You can’t beat experience and a fresh set of eyes. So glad I went back into this. It’s funny, I never put the label on last August. Now, I feel I can.
Re: All those little tweaks -how do you judge your finished product?
It seems as though I never get the nut and saddle just right the first time around.
I seem to struggle with the neck and heel being on the chunky side where they could probably be taken down some, although I don't think any "owners" have ever complained about it.
Also try as I may to find and take care of all the little gaps between especially the binding and body I always seem to have them show up later at least once a few coats of finish are on. They're sure easier to fix BEFORE any finish us down.
Post by phavriluk »
My experience has been to never accept a job as completed until I inspect it after a night's sleep. I can't count the number of times that I've unconsciously rushed a task until I look at it after being away from it overnight.
the more skilled you get the more wrong you find. Its the little details that can drive you nuts. A not perfect mitre and not perfect finish. It is the small details
Skarsaune
Post by Skarsaune »
I definitely tweak a setup several times, sneaking up on nut slot depth & saddle height.
Sleeping on it is definitely a good idea.
I have taken a chunky neck down as well.
Srick
Post by Srick »
Many of the “not perfect” visuals (like the missed miter and the veneer patch) were disguised with some acrylic paint and a fine brush. This has worked so well, that I have to do a double take to find all of the ‘clams.’
Skarsaune
Post by Skarsaune »
I forgot where I saw it, but I picked up a good piece of advice re: building and mistakes.
Strongly resist pointing out said mistakes, which seem glaring and obvious to you, to others when showing them your guitar.
remember that you are often your own worse critic
