I turned back to it a few days ago. I notched the rim to accept the back and sides. Next I'll glue the body together.
Here's the back with the rim sitting on top of it.
Here's how most of my notches look. (Those are pencil marks)
I used a file to get the notches 0.1" deep. I also made all the brace ends 0.1" high.
Here's an oops. Cut my notch too wide. It's on the one that will be most visible thru the hole, as well. Filled it in with bits of mahogany, super glued em in there, and then sanded flush. I'm wondering what I can use to smear in the gap that will make it look invisible? super glue w dust will just make it look darker.
Here's how I'm lining up the back. You can also see where I filled the gaps in my lining near the neck block.
Here's the top.
End block.
I guessed at the dimensions of the bridge plate by looking pictures from the UMGF bracing library.
