Finished my brother's parlor guitar!
Re: Continuing the steel sting o size guitar for my brother.
David L wrote:I'd have to hit the lottery or rob a bank to be able to afford those cool "special" clamps for that lining, but I like that it's multi axial.
I am not sure the special clamps are required. I think any old kerfing clamp (clothpins) would do.
Also I have gotten a Titanium Bridge Pin Set. They look cool though.
A nice feature is there is almost no squeeze out as the glue goes into all of the little cuts. I did no cleanup of glue in the picture I posted earlier.
johnnparchem wrote:btw I have new freinds in the shop.
Bantam chickens? At one time I think I could have recognized the exact breed of Bantams.......but I can't recall them anymore.
I somehow thought you might have a set of those bridge pins, which ones did you get? As far as squeeze out, doesn't RR kerfing do that too?
David L wrote:I somehow thought you might have a set of those bridge pins, which ones did you get? As far as squeeze out, doesn't RR kerfing do that too?
I am sorry I have not gotten a set of there pins. They were too expensive and I like wood. I have not used reverse kerfing, but you are correct that it may work the same way.
I need to put the strips in the rims, route out the kerfing and then I am ready to close the box.
Re: Almost ready to close things up.
I little more progress, Once I route the kerfing for the braces I will I have everything ready to close the Parlor guitar. I managed to get the end graft in (not super clean but I could fix it in finsihing) and the little strips on the rims. I cleaned up the braces and the top and back. I also have marked out where I have to route the kerfing.
I spent a little more time on the classical than I planned.
Re: Almost ready to close things up on my parlor guitar.
I closed the box on my Parlor guitar today. It was scarier than I thought it would be when I cracked part of the low bout off. But it was a clean break on the grain right over the kerfing so I glued it back together, glued the top followed by the back. Should be able to install the bindings and purflings tomorrow morning.
I still have to carve the neck.
Re: closed the body on my parlor guitar.
Ready for some cleanup sanding but I have all my bindings and purflings in. I am ready to finsih the neck and fretboard.
Post by Tony_in_NYC »
Beautiful! Is that ebony binding? Very nice!
