Neck taper details
Re: Neck taper details
only thing I would say is to work off center lines then cop and paste to pair up
that way you can be sure the taper is centered
Diane Kauffmds wrote: Thu Feb 23, 2023 8:36 am I've read that:
the width of the neck at 12th fret = string spacing on bridge.
I think it's meant as a guide but not chiseled in stone.
Going by the sketch I did, that's off by 1/8".
It's good to have this info. I would so the Calc, personally.
