ruby@magpage.com wrote:I bought new a 1966 Gibson B-25 (small parlor size) as my first guitar - didn't know much about such things. It had a 1-5/8" nut and I wondered for 2 years why I had so much trouble with it. Turns out I really like a 1-11/16" and do OK with a 1-3/4" nut.
I might suggest finding one the size yours is ending up and play it.
You can always do some binding, either the same color or a different color as has been suggested, and then glue some long strips onto the sides of the neck to widen them too. Might be easier than making a new neck.
Good luck
So, glue some mahogony strips along each side of the neck and blend it in afterwards by carefully sanding it--its a mahogony neck.That sounds like it might work --well everything sounds like it might work to me right now as i'm in a bit of a quandary over it all.ha ha. I will check that out in the morning as its 130 am here now
Thanks for the input and it would be so good if that did work..
Rusty
