Saga Electric Kit from Blues Creek Guitars
Re: Saga Electric Kit from Blues Creek Guitars
Post by naccoachbob »
John, thanks for the info on the sunburst.
Knowing you Ken, you'll do it with panache and it will rock.
Here's the body after finishing.
I went from 320 grit thru 2000 grit (probably overkill, but I was in the mood), then to 3600 thru 12000 in micro-mesh. I wanted it as shiny as possible before putting on Wizard's Final Cut, then Wizard's Shine Master. Ken at KMG recommended those two for my acoustic, and they came in yesterday, so why not? The picture is a bit overexposed I guess, but I turned off the flash because it gave off horrible effects that made the guitar look terrible to me. You can't see the metalflake that well except in the lower left, but I assure you it's there. Once it's put together, I'll try to get better pics. The neck will be finished spraying tonight. I'd forgotten it while clear coating this thing, so they're out of sync.
Now if I can make sense of this stupid manual that Saga sent..............
Thanks for looking,
Post by Ken C »
Bob, yeah, you do have get some better pix! I am sure what you posted don't come close to doing justice to your finish. I shot a few pix of my LP this evening. The lighting was pretty weak coming through the window, and I too didn't want to use a flash. I have found taking pix of guitars to be a real challenge. I'm getting better, but would love to be able to control the lighting better.
I have never wired an electric before either. I own a half dozen, but have never peaked under the hood. I'll probably work on installing most of the electronics tomorrow.
Good luck getting everything installed and working!
Thanks, Ken. I saw that Les Paul. My jaw is just now coming back up! It looked so good. I'll be getting with you and Johnparchem when I buy one to learn to do that sunburst finish. I like how it looks over that wood. So nice.
Here's a pic I just took.
I got all the innards done, and put the neck on to see what it looked like. One thing that didn't go well, was that all of the 11 screw holes for the pickguard/pickup assembly disappeared! (One Piece At a Time - Johnny Cash). I did my best to locate it where I thought it should be, clamped it down and drilled pilot holes. The pickguard ended up partially in the channel for the neck, so I had to shave that down. Didn't do a very good job. Also, while trying to remove paint from the insides of the channel, I broke a small piece on the treble side of the guitar. Grrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrr. I guess that'll be the signature flaw in it to show it wasn't store bought.
When putting the tremolo contraption together, the diagram showed very small screws. The same size as the ones holding the pickup assembly down. I tried that. When one of the springs was in and I was putting on another, the sumb***h gave way. Missed me tho! I found two screws about 1 1/2" long and used them. Terribly misleading. I was afraid when I first screwed it in that they were the wrong ones, but you know how that goes. No damage though. Lesson learned. Also, the upgraded Mighty Mite pickup assembly did not have the same connectors that the rest of the kit had, so I just cut off the connectors and just soldered the 3 wires and wrapped them in electrical tape just before I found the shrink wrap included in the kit. I really make an adventure out of building these things. Keeps it interesting.
Ken, 3 wires, that was it. I know you can probably buy pickups separately and do all the wiring, but I don't think I'll go that far. We'll see how it sounds though, and maybe I'll try something different next time. I have a good golfing buddy who plays and re-builds guitars, so maybe he can coach me along.
Another lesson is to tape the neck where it is covered by the guitar body. The fit was tight before I did anything, and of course adding clear coat to the neck, and paint and clear coat to the body made the cavity small enough to be unworkable without some sanding and such. Next time, I'll tape it just shy of the "show" side.
The thing with electric kits is that the painting and finishing takes a long time, but assembly is pretty quick. Strings were not included, so I didn't put on the tuning keys yet. I don't think I need to level the frets, but I'll check to make sure. All that's left is stringing up - which is something I've never done. And then setting the bridge so that intonation is correct. Another new challenge.
Tomorrow I buy strings, set the action and intonation roughly, and play it a bit before taking the neck back off to let it cure.
Oh, any comments on how I did the headstock? I took the Peavey I have an roughly imitated it, but changed it a bit. Does it look like any other brand?
Thanks for looking,
Bob,
The strat looks great put together. I am starting to put mine together tonight. It is interesting that your neck was tight. The neck in my sega kit was rather loose. I have been counting on the finish to tighten it up. I see how it looks when I screw it on.
Ken I looked at your les paul, wow!, I am going to have to spend more time polishing mine. yours looks great!
Post by Ken C »
That's a great color, Bob. I have a Fender Mustang in a red that looks pretty close to that one. Great looking electric! Sounds like your wiring went in quite easily. All your parts came with the kit? I had to buy the pups, pots, switches, plates, and everything separately.
Make sure you post how the electronics sound. I have always wondered about the stuff that comes in those kits, which is why I went the route I did. But buying the parts separately really adds up!
Again, great looking electric!
Ken, here's a picture of the electronics. John supplied an upgraded set like I said, and they both look very similar. It was just 3 wires like I said. It was stupid easy for me.
This is the Mighty Mite set.
The 2 black wires at the bottom are grounds. One went to the tremolo, the other I just curled up and taped. The top wire on the left has a black and a white that go to the output jack. On the original set, the connection to the tremolo was blue. That's all there was to this one.
Not sure if better pickups come with an assembly like this, but is sure was easy.
glad you having fun with it. Let us know when you are taking your act on the road. If you play here we will show up LOL. Looks nice and red is my favorite color
john
Which Smothers brother was it that always acted dumb? Tom? If I went on the road, I'd have to steal his stuff, 'cause I can't play that well. But it was fun. I'll have to figure out how to set intonation on this one though. Not sure how big a problem that is, but will find out soon.
Oh John, I figured out what I called you about last night. So thanks anyway. Sorry I gave you my wife's cell instead of mine. Natural reflex.
Putting strings on right now to listen to it before cleaning up the neck. I know, I know, but I couldn't wait.
Post by Ken C »
Bob, You got off easy with the electronics!
Big time, Ken!
Just strung it up. Man the action is soooooooooooooooooooooooooooooo high.
Playable, kinda, well, not really.
Gotta learn how to do that, too.
Anybody know any tutorials about setting up and intonating an electric?
It sounds pretty good to me, but then again, I'd like my friend to come by and play it so he could tell me.
