No. 4 - my attempt at a mahogany/sitka folk size
Post by nkwak »
I know that No. 3 just had a setback but I'm kicking this one off in order to take my mind off the feeling of defeat. I bought most of the materials after I closed the box on No. 3 and made a mold and forms. For inspiration I went way back: I still have the husk of the Kay folk size guitar that I took lessons on way back in the 70s. So I traced it and made a mold and bending form:
Here are the materials I have so far. Surprisingly this is just over $200:
Re: No. 4 - my attempt at a mahogany/sitka folk size
Post by nkwak »
Then when I damaged No. 3 I decided to not beat myself up but instead try to shift my attention toward something else. So I wheeled my Harbor Freight workbench into my garage and set up my shooting board and homemade drum sander. I made partial progess: I'm still chasing away the daylight on the joint and only have the sides down to 1.4" thick.
Good for you. We've all had our problem builds. I'm glad you haven't given up. I had to totally restart my #2 after several setbacks. If you build long enough, it'll happen.
Post by nkwak »
Thanks, Diane. From now on I'm avoiding climbing cuts! My sides are now thin enough to bend but I want to joint the back plate and soundboard first and run them through the drum sander before I put it away.
Post by nkwak »
I’ve got the sides bent and in the mold, blocks installed and the top kerfed lining installed. I upgrade my spreaders with new turnbuckles so that I can concentrated on planing at the back side rims so that I can do the lining on that side. Looking ahead I am considering on adding spruce side braces because the mahogany wants to relax and I’m afraid of it cracking and cupping.
Post by nkwak »
I took a day to refine my mold and make sure that it holds everything in place. I did this because I noticed that I wasn't sanding the back level.
Post by nkwak »
I kinda got the rosette done:
The Dremel for the outer rings isn’t a double fluted bit so it didn’t cut cleanly and I didn’t rout it very deep. When I glued the purfling strips in they were too tall to scrape so I ended up pulling them out. The black/spruce dust from the scrapings/sanding worked its way into the channels though, I was nearly meticulous in measuring the gaps, I’m out if black strips and I broke the bit anyway so I’m loathe to do it completely over. The channels aren’t completely full so I’m gonna sand the scrap purfling and sprinkle it in and set it with thin CA. The herringbone ring went in perfectly and I’m proud of that at least.
Neil
Since the purfling channels are very deep can you recut them couple thousands deeper to clean the up?
Also you could cut them a bit wider too to clean hmthe sides and the add a black or white strip to your purfling scheme? We've probably all had to do this at least once and it can turn out looking like you planned it.
Give it some thought.
(The herringbone looks great!)
Post by nkwak »
I may just do that, Kevin. I have more purfling and new bits on order.
carld05
Post by carld05 »
How about using an inlay powder in epoxy like these https://www.amazon.com/Inlay-Powder/s?k=Inlay+Powder. I've done that on some knife handles with my grandkid"s names.
