My 000 Deep Body Kit
John J
Re: My 000 Deep Body Kit
I noticed that I seem to be slowing down as I move closer to the finishing stage. I think I'll go with Tru Oil. It's amazing to think the construction process is nearing the end. Anyway I glued the fretboard on then moved on to sanding the neck and started dressing the frets. Thinking about what to do for the next one.
Learning every day.
John J
Frets are dressed and cleaned up. Nut slot cut and cleaned. Shaped my headstock. Shaped the underside of the bridge. Nice method. I think I'm down to masking off the bridge plate as soon as I sand the top. I'm planning to shellac the top after finish sanding before I sand the sides. I understand that seems to be the method to keep it clean.
Learning every day.
It looks great! A deep bodied 00 is my next project. You're right; as you get toward the end, things slow down to a snail's pace. Finishing took longer than building.
mnmusic
Looking real good John.
I have a question. What does a deep body do for the sound of the guitar? More volume perhaps or more bass?
Thanks,
Thanks,
Coming along nicely. You'll be pickin and a grinnin soon.
John J
From what I understand the extra 1/4" depth gives you a little more volume and bass.
Learning every day.
John J
Sanded the top to 600. Put a few coats of shellac on for protection while I sand the back and sides. Plan on a couple of coats of Zinsser seal coat for pore fill and then go the Tru Oil route. My test pieces look very nice.
Learning every day.
John J
Hi Diane.
I'm planning my next one already and pretty sure I'm going to do a 00 as well. What kind of woods are you thinking? I wonder if certain woods/combinations work better for the small body guitars.
Thoughts anyone?
Thoughts anyone?
Learning every day.
Hi John,John J wrote:Hi Diane.
Thoughts anyone?
I'm using cherry for the sides and back, and engelmann spruce for the top; I'm using ebony for the fingerboard and bridge, along with bone for the nut and saddle. I'm hoping this combination will give it a well rounded sound. I'm making a deep body, so hopefully that will help with the volume and bass. The neck will be cherry.
John J
Working on the finish. I feel that I'm the least skilled in this part of the project. The pores did not fill very well but I actually don't mind that so much. The wood has so much character. A couple of questions though. I've done 3 coats of Zinsser seal coat and about 5 coats of Tru Oil. Can you do anything about the pores at this point? More bothersome is that I have found some scratches I hadent noticed before. Once again can anything be done now?
Learning every day.
