Guitar #4, I hope
Re: Guitar #4, I hope
This may end up being my dogfight guitar -- so ugly I wouldn't take it to a dogfight. We'll see.
I routed out a pocket for the end wedge and inlaid it. A bit of the top binding chipped out -- incompetence strikes again -- but overall I guess it's not too horrible. I'll try to fill the gaps along the edges of the wedge with rosewood sanding dust and glue.
I don't want to blame Parkinson's disease for all my screw-ups, but it is definitely making things more difficult than they use to be.
[Later] With more sanding and filling, and a couple wash coats of shellac, it looks fairly decent. (This picture was taken prior to that cleanup work.)
...or maybe not. The back is looking pretty good.
I may have mentioned it before --- I was planning to use the fingerboard from the butternut neck disaster of my 3rd guitar. The fingerboard is fine, it was just the butternut neck that was a problem. Anyway, after further examination I've decided to make a new fingerboard. The old one is for a 1-11/16" nut and 2-1/8" 1-6 string spacing at the bridge. I want a 1-3/4" nut and a 2-1/4" string spacing. It also has the OM-42 inlay set, which is very nice, but for this guitar I'm going for the minimalist look, and that inlay set is certainly not minimalist.
Talladam
The back looks really nice.
This morning I cut the neck dovetail. The process went quite well. No catastrophic disasters. I think I probably should have made the neck pin longer though. I figured 1/2", but the neck is Spanish cedar, which is very soft, and I'm not sure 1/2" is really enough. Others figure 5/8" to 3/4" as routine, in stronger woods, so compared to those the 1/2" is pretty short.
How long do you make yours?
jread
Nice! I'm getting ready to make these cuts. May I ask your method of cutting the mortise? Leaning towards a simple Japanese pull saw, drill bits, and chisels which I finally learned to really sharpen thanks to Diane and her advice on the Alisam sled. I fixed up every bevel in the shop and boy, what a difference! I am considering a router though so was just wondering.MaineGeezer wrote:This morning I cut the neck dovetail. The process went quite well. No catastrophic disasters. I think I probably should have made the neck pin longer though. I figured 1/2", but the neck is Spanish cedar, which is very soft, and I'm not sure 1/2" is really enough. Others figure 5/8" to 3/4" as routine, in stronger woods, so compared to those the 1/2" is pretty short.
I made this setup:
https://www.stewmac.com/How-To/Online_R ... tions.html
The fixture to hold the neck and the guitar body wasn't difficult to make, but can tell you that after making the templates, StewMac's price of 89 bucks for the pair didn't seem so outrageous.
I have a DeWalt DWP611 trim router, which I like. It is possible to buy 1/8" and 3/16" 3rd-party collets for reasonable money. The ability to hold 1/8" and 3/16" shank cutters is very handy.
Here is a rather bad photo of the setup.
It is progressing. I've carved the neck and glued the bridge in place on the top. To glue the bridge I used a custom clamp. I got the design from somewhere or other, it's not original with me. I used 250-gram hot hide glue for the first time. Previously I'd used 190g. The 250g has more body, and is tackier.
I've also got the frets in.
I put in the fret position markers. They are pretty subtle. I got the idea from Carter. They are just bits of ivoroid binding, glued into slots along the edge of the fingerboard.
I never thought of using ivoroid for position markers. I like the idea and look.
I'm trying something that seems to be working. I fitted the dovetail joint, mashed it together with a couple of clamps, then put a screw through the heel block from the inside, into the heel of the neck to keep the dovetail joint from sliding apart. The screw doesn't hold anything to speak of, it just keeps the joint from sliding.
I've put the strings on and tuned it up. This has let me check string height and neck alignment with the guitar assembled and under tension, but it's not glued so I can take it apart to adjust as necessary. (The neck alignment does need a bit of correction.)
The sound is quite something. I'll post a sound sample in a bit, but I think my top bracing scheme is a definite success.
