Not sure about drilling for truss rod access
Red Dogg
Post by Red Dogg »
On a StewMac OM kit...
I'm ready to glue on top and back but the instructions do not even mention drilling the shoulder (transverse?) brace for access to the truss rod. Since I can't dry fit the neck yet, I'm not sure where exactly to drill for allen wrench access. The neck block came pre-drilled for a rod, but I'm not comfortable assuming that hole will line up with the truss adjuster on the "hot rod" style. At least I'd be able to re-drill or enlarge the neck block hole after the box is together. Drilling the brace in an assembled box is a bit of a problem since I don't want to destroy the integrity of the brace.
If I don't drill the brace, would I still be able to access the rod if needed?
I've emailed SM about this, but no answer after several days. Any advice?
TOM
Re: Not sure about drilling for truss rod access
drill it
You should drill a hole in the center of the transverse brace, but lower, toward the top. I use a 5/16" bit.
jread
Post by jread »
What I did was lay my truss rod on the inside of the top pushed against the brace and drew a pencil line around it. Be sure to check that the truss rod wrench goes into the rod before gluing the neck. I had this issue on my last build where i needed to make the slot in the neck block just a little deeper so the key would easily go into the rod.
