I recently purchased a bridge blank and fretboard blank from a well known, reputable supplier.
As I have in the past, I expected to see quarter sawn material used to make these blanks. I’m disappointed with what I received.
In the photos, you will see I have drawn a white reference line at 45 degrees.
So, what are your thoughts?
Are these ok to use?.......or am I asking for trouble somewhere down the line?
How far off quarter is too far?
Cbstark46143
Skarsaune
Re: How far off quarter is too far?
Just my opinion, but I think off-quarter like that for a bridge is fine.
A lot of the stress on a bridge comes from the saddle slot - that's where cracks always seem to occur - so the grain not being parallel to the slot actually seems like a good thing.
I have a foggy memory of reading that in one of my reference books as well - I may try to look it up when I get home.
Interested in others opinions as well.
that should be fine
Skarsaune
From Tim McKnight, McKnight guitars - "For bridges I prefer wood between quarter and rift. I like about a 20* to 35* lean of the grain lines but not a true 45* rift angle. These cuts will be almost as stable as QS cuts. When drilling bridge pin holes the hole will "likely" bisect several annular rings making the wood far less likely to split. If you bore a perpendicular hole in a true quartersawn piece of wood, the wood could be more susceptible to splitting when side loaded. IMO, its even more important in the bridge slot where there is a greater side load and torquing effect on the leading edge of the saddle slot."
Knew I read it somewhere.
