Hello again,
Build: Stew mac 000 bolt-on neck
I am at the point of locating my bridge and setting neck angle.
According to the stew mac instructions, to set the neck angle (side to side and tilt) I must first locate the pre-slotted bridge on centerline (as well as correct distance for intonation).
I have the stewmac saddlematic which will help me get the correct distance but how can I ensure the bridge is ACCURATELY on center?
This is necessary to do first as the instructions want you to use the bridge as a fixed landmark to set the necks side to side angle.
How is best to acheive this? Thanks.
Locate bridge dead center?
pryde
Re: Locate bridge dead center?
Once you establish your neck angle and center you place the bridge to the center line of the neck.
Here is a video you may find interesting.
