The stew mac instructions say to draw the nut line right at the break angle of the headstock (see photo) and then glue the fretboard right at this line. The problem is that if I bring it up to the nut line, the 12th fret doesn't line up right to the body (see other photo). Looking at other's build pictures and the blueprint it looks like the 12th fret should be directly lined up with the body/binding line.
So then how/where should the fretboard be glued? Do I move it down (away from the nut line) to line the 12th fret up to the body, or do I glue it right on the nut line? Thanks for the help
