back first?
johnd
back first?
Does it matter if the back is glued before the top? Just wondering, if the top is glued first how do you clean up any glue squeeze out on the back? Through the sound hole?
Re: back first?
Kinda like asking what glue is 'best'. :) Good arguments for each side. So...
Do what you feel comfortable with. If you do the top first, use that as a trial run to get the right amount of glue on for the back assembly. There is no real opportunity to clean up the back, if the top is on.
johnd
Re: back first?
Thanks Darren!
Re: back first?
Where'd my post go? Oh well, here it is again.
I've done both but now put the top on first in case I want to scallop the top further after it's on. There are probably good reasons for doing the reverse.
CavalierKingCharles
Re: back first?
To me it doesn't matter, I haven't had any trouble with glue squeeze out.
I do cut the brace notches for the top and back while still in the form and before I attach either.
Learned that one the hard way...
Scott
Scott
Re: back first?
I will say that it can matter to a degree. I use a dish and I will do the back first. This helps to eliminate the risk of racking the body but if you are carefull it won't matter much. I do the backs first so I can clean up the back
johnd
Re: back first?
Glad I asked! I think I will do the top first. I want to clean up some mistakes while the top is on the rim. The notches for the bracing could be better. I did a much better job on the back
Thanks,
Thanks,
Tom West
Re: back first?
johnd: If you are having trouble getting clean notches in the linings you may want to consider reversed lining if you use the regular. Much less chance of blowout using the reversed linings. I also put the top on first but both ways work equally well for different reasons.
Tom
Tom
