It actually looks much worse in person... problem areas are at the headstock end and the point of the heel which is facing directly away from the body, where it is all endgrain as well. the rest of the neck looks great. I'm not convinced it's rosewood dust because the issue is in the heel as well and there's no rosewood close to that. The rest of the neck is very smooth and clean. Is anything going to clean this out of the pores or should I just keep on sanding?
maybe it's just the nature of this wood but I'm hoping not. thanks for any help you can give.
