Trimming back and top overhang
Sunflash
So I just got my back glued on, I fixed the split in the back with CA worked good but I didn't do as nice of a job as I would have liked.
So, now I am wondering how I should trim the overhang of the top and back? The plans say a file and a knife but don't really go into actually doing it.
Re: Trimming back and top overhang
I use a flush trim bit in a router. Take your time ,
watergunn
I do the same thing as John.
mjmeehan
Could you also use a flapper wheel in a router/ dremel tool? Seems like this would all but eliminate the chance of tear out.
That is what I have been considering. I've always used the flush trim bit with mixed results. (Though I have to admit that sometimes I have a hard time with "Slow"!)
you will be there forever.
I've not tried a flapper......but make sure you don't let it dig into your sides if you give it a go.
A flush trim bit makes this simple. Just start at the peaks of the bouts and work into the waist then back to the peaks and work down toward the neck/tail blocks. Finally, go all the way around the perimeter keeping the router held tight to the sides. Just work slow and I would be surprised if you have problems. Get Bill Cory's book and it shows you just how to do it.
I use the 2" Robo-Sander.
