Mortise and tenon
Mortise and tenon
Best way to adjust a m+t neck angle? File down cheeks or shim the tenon? Or something else?
Jim_H
Re: Mortise and tenon
I guess it depends? Im guessing the neck cheeks are flush against the side of the guitar?
I'd start with flossing the cheeks until you get the angle you want. if the tenon is also seated against the neck block, it might need some adjustment too?
The cheeks are what make the adjustments to the relationship of the body.
It's not my guitar, I just need to pass on some info, thought it might be a good topic for discussion.
If we put aside humidity, neck relief, truss rod problem, bridge height, saddle height and like that, theoretically, and just concentrate on the m+t, what would be the first thing to try?
Thanks Jim, the answer has to be one of those things.
Thanks John.
Even with MT a re-set is a last resort The good news is that you usually make an adjustment without prying the fingerboard extension off the sound-board. If you can get the joint loose at the body the check angle can be change by sliding sand paper between the neck and the body -- this works only if the neck needs to be tilted back away from the top. Nine times out of ten this is the case. All that said I would not venture a guess at corrective action without seeing some really, really good pictures -- more then likely I'd have to have the instrument in hand. Repairing a guitar is not the same as "correcting" an assembly problem.
I'm just going to stay away from it and refer him to an experienced tech. Warranty and all that...
Thanks Ken
Thanks Ken
I'm not real clear on this. I do the flossing thing to even out any irregularities between the cheeks and the body. However, to change the neck angle, not so much. I've attached a pic, everything's exaggerated for clarity - I drew a red line - is that what we try to accomplish?
Jim_H
when you are flossing, you have to put a small amount of pressure on the neck in the direction you want it to move, so you are removing material from one area. Same thing applies if you need to adjust side to side.
What kind of guitar is this? Is the neck off of it already?
Pics or it didn't happen! :p
But unless you floss a new angle you haven't accomplished anything. That's why my cheesy red line was drawn as it was. My cat agrees :-)
The aim is to keep the cheek line a straight line, but sand an angle into it? Sounds tricky to me.
Jim - sorry, read your post too late. Thanks.
