1st build delay
1st build delay
Received my Blues Creek 000 kit yesterday.
Unfortunately, my shop humidity level is floating between 55% and 60%. So should I hold up on doing anything with the kit or are there tasks that can be done even in the somewhat moist environment?
tb
tb
Re: 1st build delay
once you hit 50% you will be ok . Now you can make you go bar deck and other jigs . get your shopping list together.
Re: 1st build delay
You can also assemble the rim now. Don't do anything with the top or back until humidity is about 40-45%. Low humidity is better than high. I brace my plates in January and get them glued on by February so I know RH is low.
Re: 1st build delay
Bought just about everything I think I'll need for a home made go-bar. Hardware and 3/16" fiberglass rods, rubber tips, etc cost me $36. I have plenty of scrap wood lying around for the top and bottom of the go-bar. In fact, I have a bunch of smaller scrap pieces of T&G red oak flooring that should do the job nicely once glued up.
Downloaded and printed the Pick Guardian neck gauge drawings and will start up on my 16" radius fretboard sander.
Tony, when you say "assemble the rim" do you mean glue the head and tail blocks to the sides and glue up the top and back kerfing?
tb
tb
Re: 1st build delay
Thats what he means, Tommy, and exactly what I was thinking. This is a great time to get your topoling going, if you have to build any, but you can also start working on your rim. No real reason not too.
MuddyFox
Re: 1st build delay
Are necks also dependent on atmospheric conditions?
Can one start by doing some neck/fretboard work while waiting for favorable RH?
Re: 1st build delay
"ALL" wood reacts to atmospheric conditions. There are many variables (too many to list) that affect how much or how little.
MuddyFox
Re: 1st build delay
Is that a "no" on starting on the neck with RH in the 60es?
If doing the rim is ok, I should think neck would be rather safe as well?
Re: 1st build delay
you can set up the blocks and get the kerfing in and trued up . Inalys on the fretboard . and plan . That will be the fun , anticipation is a lot of fun . Twas the night before building -
Re: 1st build delay
Well said John, planning, imagining, daydreaming, wishing, etc... is half the fun!
