Loose kerfed lining
Re: Loose kerfed lining
If I had that many clamps, I would sure use them! I have 'enough' but hey, I like seeing that full clamping.
bnjp
I have about 50 of those clamps! That's enough to do 1/4th of the guitar when you clamp them that way. I bought most of them at a local tool outlet for about 80 cents each...then got a few more from Amazon because I wiped out the stock at the outlet. They are way stronger than the plastic versions I've used...and definitely better than the clothes pins.deadedith wrote:If I had that many clamps, I would sure use them! I have 'enough' but hey, I like seeing that full clamping.
Bryan
