Neck to body Alinement
Re: Neck to body Alinement
Deleted by poster.
Tom West
Isaac : If you are building with a 25.4 scale and about 3.7/8 depth at the neck you should end up removing about .045 or so as John has discribed. Use this as a referance to make sure you are on the right track. It's harder to remove wood to bring back an over set neck then it is to go the other way. I like to start near the board and remove a thin shaving of wood from the cheeks,about 1/2" long,and then use a sanding block made from dead flat wood with adhesive backed abrasive. Work your block favouring the top end of the heel near the board.Be careful not to remove wood from the bottom end of the heel. Count your strokes,then do the same to the other cheek. Check your angle on the guitar and also check alignment with centre line. The undercutting you first talked about is only to make it easier to fit the cheeks to the body with less work. Make sure you have at least 1/8" of the outer edge of the cheeks contacting the body. Hope you can follow this,would be so easy to show you if we were there in person.Good luck and let us know how you make out. Good luck.
Tom
Tom
Tom West
Isaac: We have not heard back from you. I hope I did not drag you into the swamp....!!
Tom
Tom
Sunflash
Lol, sorry. I had a busy week.
No, you guys helped a lot! I got a perfect fit. I had to take a little more off and then I put a strip of sand paper under it pulled it out a few times and Vala! I just put on my pore filler yesterday and made a spray booth.
Tom West
Isaac: Sounds good,glad to hear. Take care and report back after you put the strings on.
Tom
Tom
