Next step up from a Dremel?
My compressor is only a 4 gal. job so I can't go air tool.
Which brand/model, non pneumatic, will give me higher quality and less runout than a Dremel?
Will be used for not so intricate inlay work.
-tommy
-tommy
Re: Next step up from a Dremel?
dremels are less than perfect and if are upgrading but don't want to go to air , your next upgrade would be foredom. They are a lot better and less runout than any dremel,
Tarhead
You can remove the bearing slop on the Dremel with a thin section of shrink tubing around the bearing. Frank Ford's idea here:
http://www.frets.com/FretsPages/Luthier ... mbear.html
It's still a Dremel as far as power so take light passes.
That's a money saver. Thanks.
So now that you brought it up, I'm wondering, If I bought a new Foredom,
would I select higher torque/lower speed or lower torque/higher speed??
-tommy
-tommy
derf
darn tommy !!tommyboy wrote:That's a money saver. Thanks.
-tommy
another thing to add to my list of gotta replace !
forgot i burnt out all 3 of my dremels a few years ago :(
saltytri
These Proxxon tools are much better than any Dremel I've seen (except the one I have that is about fifty years old and sill running fine):
http://www.amazon.com/Proxxon-38481-Pro ... ds=proxxon
http://www.amazon.com/Proxxon-38472-Pre ... ds=proxxon
RobbieC
Proxxon. Better motor, better bearings, more durable, etc. Unfortunately, the StewMac attachments like their Precision Router Base won't fit. I made a base for the Proxxon to use with SM's bridge slotting jig. See the Frets.net forum for more info:
http://fretsnet.ning.com/forum/topics/p ... t%3A112300
