Guitar Vice
glasalle1
Guitar Vice
Hi All,
I built this Guitar Vice last week after reading about it on Kathy Matshushita's web site. I lined the plywood with cork, but will add some foam or carpet to help protect the guitars more: Glenn
Re: Guitar Vice
Nice! I built one of those after 4 or 5 guitars and kicked myself for not doing it sooner. Don't forget some kind of strap to keep the body from dropping to the floor.
Also, don't leave a finished guitar in this vice, it will imprint a pattern (carpet, rubber mat, etc. ) on the finish.
Re: Guitar Vice
Yep, I made one also, after my first guitar. I covered the plywood with thin dense foam, I can blow it off to keep it clean. My pipes are close enough together that the lower bout of even an OM won't pass through. Works like a champ.
glasalle1
Re: Guitar Vice
Right now, I have the pipes a bit further apart - about 16 inches - as my jumbo is 17 1/4 across lower bout. I am thinking of buying 2 more flanges, and putting those closer together, so I have options :-).
I was looking at foam... i see 3 in foam on ebay, but i think that is too thick. I will keep looking til i see something that looks good
Glenn
Glenn
Tarhead
Re: Guitar Vice
Find a local upholstery shop and get them to cut the exact pattern you need for the cushions and attach them (unless you have some spray adhesive). They also have webbing for safety straps.
Re: Guitar Vice
I foam I used I got at OSH, it is quite thin and black in color, like 1/8" but it is dense so it provides protection. You just want to make sure there is nothing on it when clamping against the top.
musicman2000
Re: Guitar Vice
I built the same vice using Bill Cory's manual. I used 1/2" foam that I found at Joanne Fabrics. A little rubber cement stuck it right to the plywood. Pipes are 16" apart. Can't wait to see how it works!
Tom
Tom
Re: Guitar Vice
A small stool under the vice can support the box and keep it from falling through. Be sure to make the faces out of thin enough plywood that they can flex and not stress the middle of the top and back, rather put the strain where the sides meet the top and back and can support it. 1/4" or maybe 3/8" plywood, but mine are 1/4" and work well.
Ed Minch
Ed Minch
kmatsu
Re: Guitar Vice
I attach two bungee cords (I hook them into eyelets on the bottom of the clamp boards), and have them criss-crossed underneath.darren wrote:Nice! I built one of those after 4 or 5 guitars and kicked myself for not doing it sooner. Don't forget some kind of strap to keep the body from dropping to the floor.
Mitch
Re: Guitar Vice
Coincidentally I was building a vise this week too. Thought I'd post some pix since the design it is slightly different due to my bench isn't thick enough for screwing on pipe flanges and I wanted it easier to remove.
The jaws are 1/4 ply with carpeting attached with spray adhesive. The plywood was warped so i orientated it to conform to the curve of the guitar front and back (how often is warped plywood an advantage). Both jaws are removable, so i can also use it like a Moxon vise for clamping wide boards when building furniture. Best part is that it's built from scraps and clamps already around the shop.
MItch
MItch
