I finally got around to putting together the parts of my new side bender design.
This is what I consider the best combination of features. it uses cantilevered presses like the LMI so that you can load/unload from the side, but it allows you to use either/both the LMI or Fox/BCG type rollers on the side molds. I also have a different cutaway press that allows for a quick-connect strap on the front, so that it balances the tension load on both the front and back sides... not sure if it is needed, but I allowed for it in the machining, just in case (I'll show pictures of that part when I've assembled the next bending machine - I'm making four).
This one has the cut outs for the LMI controller, which is what my buddies at PBG use, but for mine I'll have a different cutout to insert the heat controller and timer like BCG and others use.
Once I work the bugs out of this design, I may be making the cut files available to others who would like to build their own. Or if someone else wants to provide kits for this? We'll see...
New Side Bender design
rienk
rienk
Re: New Side Bender design
Here is my Side Bender with a mold in it, as well as the waist and cutaway cauls installed.
I hope to be bending some sides next week!
It looks nice. I can't tell from the pictures, can you bend both sides at once? Can't tell if th eform is wide enough for that or not. Can you bend binding/purfling on the form? Couldn't tell what kind of support was in the middle of the forms.
rienk
No, this is for one side at a time.Darryl Young wrote:It looks nice. I can't tell from the pictures, can you bend both sides at once? Can't tell if th eform is wide enough for that or not. Can you bend binding/purfling on the form? Couldn't tell what kind of support was in the middle of the forms.
It should be able to do linings, bindings, purflings (function of the slats), though I may need to put in some cross dowels for the small stuff?
