Planer/Thicknesser
Zen
Planer/Thicknesser
I am about to invest in a planer/thicknesser for my workshop and just wondering what your thoughts are on having one.
Firstly is it necessary for guitar building--mostly acoustics so far but hoping to do an electric soon
Is the combo version preferable or would separate machines be better ?
I live in Ireland so its a quite a big investment compared to Usa price wise--maybe 900 euro for a Charnwood W583 10" x 7" Planer Thicknesser or a Record planer /thicknesser
There are desk top versions but not as powerful
My wife--She who must be obeyed--seems to think I may not need it as the wood I will be buying will be already planed but obviously thats not the case as the sets I see on lone will still need thicknessing
Just wondering what you guys use for this
Thanks and happy new year to all.
Rusty
Rusty
RUSTY
Re: Planer/Thicknesser
The power planer is not the best for acoustics as it tends to destroy wood at the thickness we need in acoustics A thickness sander works best.
B. Howard
The only advantage of a combo machine its the space savings. If you have the room separate machines usually work best. A joiner its very useful. A planner can be helpful.
Zen
Thats what I was wondering John but apparently this one -the Scheppach HMS2600ci can thickness down to 1mm . It has 3 knife blades for a very smooth finish .tippie53 wrote:The power planer is not the best for acoustics as it tends to destroy wood at the thickness we need in acoustics A thickness sander works best.
Confused now
Rusty
RUSTY
I don't think you want any power machine using blades to thickness tonewood.
A planer and thicknesser or a planer/thicknesser is a must have in a woodworking shop.
Not so much in a lutherie shop. Perhaps there is a cabinet shop in your area that will thickness your
tops and sides for a reasonable fee or your tonewood source could afford you that service.
You'll need to thickness a whole lot of guitar wood to recoup the cost of a thickness or drum sander.
$700. US is entry level cost of a decent 10" drum sander. I don't include Grizzly's lower cost drum sanders
because although I've never used one, the results I've seen and the reviews I've read are not good.
-tommy
-tommy
Zen
Thanks Brian . Over here in Europe we call them planer/thicknessers but I think in Usa they are jointers but they do the same thing basically ie planer on top and then thicknesser underneath and the one I was interested thicknesses down to 1 mm with a very clean finish.B. Howard wrote:The only advantage of a combo machine its the space savings. If you have the room separate machines usually work best. A joiner its very useful. A planner can be helpful.
. Just wondering if its overkill as I have just got myself a belt/disc sander and a bandsaw so I dont know why I thought the next thing should be a Thicknesser.
I envy the choice you guys have when it comes to machinery for woodworking. I am visit over there in march--California-and will be spending some time browsing the big stores no doubt .
Rusty
RUSTY
Zen
Thanks Tommy. You got me thinking now because I had never thought of a drum sander but over here in Europe we use different names for some of the machines,tommyboy wrote:I don't think you want any power machine using blades to thickness tonewood.
-tommy
This is the planer/thicknesser I was thinking about but perhaps youre right about using it for tonewood even though it takes wood down to 1mm
http://www.youtube.com/watch?v=w75V4k2rebk
RUSTY
Zen
Then I found this and you guys are right--I dont really really need one--maybe !! My wife will be so happy !!!
http://www.youtube.com/watch?v=FXuh_Q02DP8
RUSTY
Zen
John, when you say Thickness sander--can you elaborate as we have different terminology sometimes over here for tools. Is it a drum sander you mean ?tippie53 wrote:The power planer is not the best for acoustics as it tends to destroy wood at the thickness we need in acoustics A thickness sander works best.
Could you recommend any?
Thanks John
RUSTY
B. Howard
A joiner, or jointer depending on whom you speak with, is a tool that will put an absolutely true and straight edge on a piece of lumber indexed at a perfect 90 degrees to another face. a Planer is a tool that will surface one side of a board and make it a uniform thickness. Two different tools, two different jobs. to make absolutely square and true stock one must perform both operations.Zen wrote:Thanks Brian . Over here in Europe we call them planer/thicknessers but I think in Usa they are jointers but they do the same thing basically ie planer on top and then thicknesser underneath and the one I was interested thicknesses down to 1 mm with a very clean finish.B. Howard wrote:The only advantage of a combo machine its the space savings. If you have the room separate machines usually work best. A joiner its very useful. A planner can be helpful.
Rusty
