binding tower info needed
newbybeau
hello all, this is my first post.. I have been very inertested in all the information I have read here. on my first bild and have closed the box up and learning by many mistakes on this first one. I have been stuck on a good way to route the binding channel and have decided the best way for me to go is to build a binding tower. I like the one that john hall uses very much as well but in my small space storage is at a premium. could some one give me the rough deminsions fo the towers I have seen on this site. height,width and depth. I think I can figure it from there. thanks so much in advance. Beau
ps i haave found that building the tools is almost as fun as the guitar itself
Beau
Opportunity is missed by most people because it is dressed in overalls and looks like work.
CavalierKingCharles
Re: binding tower info needed
Hello and welcome, here's my 2 cents.
I use the articulating arm version, it folds up and it's easy to pack away.
Plus it was cheap to build. Like you, I do enjoy building the jigs and things
Whichever way you go, you probably want to build a cradle as well.
Scott
Scott
the arms don't work properly without the carriage.
In your case you can see the angle transfer at the top , this will make the binding appear to lean into the top . The carriage works to keep the sides perpendicular to the table and parallel to the cutters.
newbybeau
thanks for the reply this looks like it could fit the bill nicely do you mind if I ask where the chrome bar you use for your pivot came from yes I do plan to build a carriage as well thanks for the advise
Beau
Beau
Beau
the arms use a commercial work slide and are stainless steel
the parallel arms are something I machine.
Scott, I like that setup. Where did you find the rod, the bushings that fit it, and the locking collar that comprise your tower? I'm guessing you could make a version that clamps to the table and is easily unclamped and removed for storage.
looks like a curtain rod I may be wrong.
CavalierKingCharles
It's just a 3/4 steel rod with brass bushings from Ace Hardware.
It slides in to a makeshift bracket in my bench and I take it out when not in use.
When making things like this I just wing it, I always tell myself "it's just a prototype" and I'll make a better one when I get it right.
I have lots of prototypes right now ;)
SA
SA
CavalierKingCharles
One more
newbybeau
Well finally found some extra time and built a binding machine. Similar to the one John Hall demonstrates on YouTube. Worked pretty well. Sadly I have not figured out how to post pics of my meger success Still need to figure out how to get rid of the fuzzies with out causing to much change in the channels Also I could make some minor improvement in the machine but I am pretty satisfied. Thank you. I would not have had as much success without the info posted here
figured out how to post a couple of pics cant do it on the i pad had to go to pc
Beau
