heating blanket noise
segovia
Hi
John - I think this is one for you, do your heating blankets buzz when the power is applied ?
Re: heating blanket noise
I downloaded Doc Watson's Deep River Blues into the blanket to cover up the buzz.
Just kidding - my overhead lights will buzz sometimes - could that be it?
Somtimes they do produce a 60 cycle hum I don't know why but they do.
segovia
Thanks, never heard it before now
The blanket hasn't been used for about 18 months, just getting back into making stuff
hummingbird
Hi John
I get the buzzing also. However, it only occurs when I'm using the controller to control the current. If I switch it to full power with no resistance it does not buzz. It's possible that the buzzing is coming from the controller itself.
Alain
the controller may be part of the cause . I use a VSI switch and I do have a blanket that buzzes on Var but it works. I will see what the supplier has to say.
Maybe the noise is turning the blanket on/off while in variable mode to control the blanket temp. See if the frequency of the "buzz" drops when you turn the dial to a lower temp and if it increases when you turn it to a higher temp. If the frequency stays constant, then the noise may not be related to the on/off control. Just a thought.
