Bridge pin hole reamers
hummingbird
Post by hummingbird »
They're expensive. LMI has 3 deg and 5 deg. Which one is best / more common. I don't want to have to buy both.
Alain
Re: Bridge pin hole reamers
the 3 degree is most common
Post by   »
Check out Grizzly.com for a reasonably priced 3 deg. reamer.
tommy
JLT
Post by JLT »
I've already got a violin-peg reamer. It has a 1/30 taper, which my toy drawing program renders as 1.91 degrees (that's the angle between the cutting edge of the reamer and the long central axis of the reamer itself, I presume). But that got me to wondering how the degrees in a reamer are calculated ... is that the angle the face is from the central axis of the reamer, or the angle formed by the faces of the cone (i.e the cutters)?
Guitar Hack
Post by Guitar Hack »
You can buy them on ebay cheap.
Ace hardware carries one for $10.
Post by   »
Guitar Hack wrote:You can buy them on ebay cheap.
Do you have a link? I can't find any on ebay. Thanks.
tommy
