Millers Falls No 7 plane
Nick R.
Hi All, I'm new to this forum and also new to guitar building, I picked up a rusty block plane at a yard sale for $3.00 when I was cleaning it up I saw the name stenciled"Millers Falls No. 07" it has a skewed blade looks to be 110* also
might be low angle 7" block plane my question How do you sharpen the plane iron, doesn't fit my sharpening jig and just not savvy enough to sharpen by hand. Thanks for any advise Nick R.
Re: Millers Falls No 7 plane
You should be able to get it on the jig. Can you post pics?
This is the first result from a Google search.
http://www.sawmillcreek.org/showthread. ... lane-Irons
A lot of jigs will take chisels or plane blades. If yours won't, you may need to get a different one.
Nick R.
Hi All, just a couple of photos
Aurthur_Jackson
$3.00! You're kidding. I'll give you $5.00 for it
I use a jig I bought from Grizzly and my old Delta wet grinder. I check the angles compulsively.
JoseManuel
Welcome, Nick! For skewed blades, try an adjustable honing guide or use a simple angled block to sharpen by hand—it gets easier with practice!Nick R. wrote: ↑Fri Feb 03, 2012 8:42 pm Hi All, I'm new to this forum and also new to guitar building, I picked up a rusty block plane at a yard sale for $3.00 when I was cleaning it up I saw the name stenciled"Millers Falls No. 07" it has a skewed blade looks to be 110* also
Lie-Nielsen sells a honiing guide adaptable for skewed blades:
https://www.lie-nielsen.com/nodes/4239/honing-guide
As with most Lie_Nielsen products the price may astonish you, but the quality is impressive.
