Thanks Ken! I like that, only problem is I can't find it on Rocklers website.
FB taper?
Re: FB taper?
I believe Rick's (runningdog's) method is the way to go -- Don't over look the template concept -- fast and totally accurate once you make the template. A hand held or table mounted router will work. Make a wider board by changing to a larger bearing. Fasten the FB to the template with double back foam tape. $.02
