Radius sanding bar vs radius disc
jjadamson
Post by jjadamson »
This is my first build and I'm in the process of making moulds, jigs etc. In the Bill Cory book, Building Martin Guitars, he uses a radius sanding bar which is also used as a caul. Will it do the same job as a radius disc which will be heaps harder to make?
Dave Sayers
Re: Radius sanding bar vs radius disc
Post by Dave Sayers »
a radius sanding disc would be better but more expensive. The bar works ok. At the moment I am using a huge pine tree in the garden to anchor my router to radius wood. I shall be attaching it to beams of wood and then using it in a backwards and forward motion. The problem is holding the timber square to it as it cuts.....It's only cutting stuff on the outside of a circle, that's a radius. Think circle and how can I cut it.
The bar can work but it does have it issues. Take your time and as you build more you will see the advantage to one jig over another. I used a bar but after about 10 builds I tossed it in favor of the dish, it is hard to mess things up using one of these.
Dave Sayers wrote:a radius sanding disc would be better but more expensive. The bar works ok. At the moment I am using a huge pine tree in the garden to anchor my router to radius wood. I shall be attaching it to beams of wood and then using it in a backwards and forward motion. The problem is holding the timber square to it as it cuts.....It's only cutting stuff on the outside of a circle, that's a radius. Think circle and how can I cut it.
Huh? What are you doing with a pine tree? Pictures perhaps?
check out ( long compass ) you can do them better that way.
jjadamson
Post by jjadamson »
Hi John, I'm a little unclear about your last comment you made about the long compass.
this is a method of making an arc very accurately , I think it was used a great deal in ship building.
Post by   »
jjadamson wrote:Hi John, I'm a little unclear about your last comment you made about the long compass.
http://gicl.cs.drexel.edu/people/sevy/luthierie/compass/Long_compass.html
Copy and paste the above in your browser. Parsing function seems to be broken.
