Posting sound samples
When did it stop being possible to attach .mp3 files to posts?
Re: Posting sound samples
should be able to
what is the size of the post?
try it now It was turned off I turned it back on
I still get this error:
[The extension mp3 has been deactivated and can no longer be displayed.]
seanbig
Testing .mp3 small file.
Sean Big
Sean@BiggerRoom.net
Sean@BiggerRoom.net
seanbig
Test bigger file
Sean Big
Sean@BiggerRoom.net
Sean@BiggerRoom.net
seanbig
Even Bigger File
Sean Big
Sean@BiggerRoom.net
Sean@BiggerRoom.net
