board style changes
board style changes
Looks like the software was updated - Sean should know that the advertisers and header image have disappeared in all but the 'WoodTones' board layout.
Re: board style changes
thanks
we will get right on it
thanks
john
thanks
john
seanbig
Thank you. After the upgrade I checked the board on Wood Tones, but forgot to check the other themes. I will take a look at this tonight.
Sean Big
Sean@BiggerRoom.net
Sean@BiggerRoom.net
seanbig
Thanks again for letting us know about this. Everything should be back and in order now.
Sean
Sean
Sean Big
Sean@BiggerRoom.net
Sean@BiggerRoom.net
I can choose from only 2 board styles, I thought there were more choices?
DaveB
DaveB
seanbig
Yes, I believe there are three. I'll take a look at that.
Sean Big
Sean@BiggerRoom.net
Sean@BiggerRoom.net
seanbig
Did anyone notice when the third style went away? Did it go away when the board software was updated on the 14th or 15th? Or did it go away after the subsilver2 style was fixed, Friday the 17th?
I don't know if any of that makes sense to anyone but me, but I'm having trouble narrowing down why the third style is not showing up.
Any help is appreciated.
Thanks,
Sean
Thanks,
Sean
Sean Big
Sean@BiggerRoom.net
Sean@BiggerRoom.net
I think it was the 17th. I'm logged on to the forum most of the day and would have noticed changes before then, I think.
DaveB
DaveB
The style I have been using was ProSilver.
DaveB
DaveB
On the 16th when i noticed the template change, i went to the ucp and checked all three templates. So at that time the third one was there. Hope that helps.
