While getting familiar with the new software I tried to search for certain members. Or even viewing a memberslist. But no access was granted.
Is that supposed to work?
No access to search members list
seanbig
Re: No access to search members list
Herman,
I'll look into that for you and let you know as soon as I get an answer.
Sean
Sean
Sean Big
Sean@BiggerRoom.net
Sean@BiggerRoom.net
seanbig
Herman,
I've made some changes. There should now be a member's list in the top right of the screen next to "User Contol Panel." Try that out and let me know if it's working for you.
Thanks,
Sean
Thanks,
Sean
Sean Big
Sean@BiggerRoom.net
Sean@BiggerRoom.net
Sean, don't know what you did, but now it's working.
Thank you. BTW you're fast.
Question: What is BB Code?
seanbig
Herman,
BBcode is Bulletin Board Code. It is used so that you can add things in HTML without accidentally breaking well formed HTML.
For instance, if you want to add a web link you can use BBcode to insert a link into your post. Many of the BBcodes you can use are shown across the top of the "Message Body" section when making a post. There are things like; Bold Type, Italics, Lists, Images, Weblinks and others.
Sean
Sean
Sean Big
Sean@BiggerRoom.net
Sean@BiggerRoom.net
