Logging into the new forum
Hi Sean,
I was not able to log into the new forum with my old username and password, so I created a new one.
It may not matter, but is there a way to fix it so my old login works? Just wondering
Re: Logging into the new forum
Hi Kevin,
I was able to get in with my old username and password, but the visible userID is no longer Ken C. If Sean and company can't change my id back to the old one, I may just create a new log in as well.
seanbig
Kevin,Kevin Sjostrand wrote:Hi Sean,
Some other people have had trouble with the "forgotten password" feature. I think I must not have gotten the email hash reverse engineered properly. The new account is fine, but I can manually go back in and get your old information working if you would like to keep your old login information.
Sean
Ken,iflyfisher wrote:Hi Kevin,
You are more than welcome to create a new account. You are right the display name is your username and this cannot be changed. So if you want to change your display name you must create a new account.
Are you Ken Cierpilowski of Kenneth Michael Guitars or is everyone around here named Ken C!?
Sean
Update: I rehashed all he email addresses and you should now be able to reset your passwords using the "I forgot my password" link on the login screen.
Reason: Update
Reason: Update
Sean Big
Sean@BiggerRoom.net
Sean@BiggerRoom.net
Sean,
No, I am not Ken Cierp. I am Ken Casper. When I registered initially I didn't realize there were so many Ken's on the forum or I probably would have changed!
If I re-register, I presume there is a posting count that will get reset?
Sean,
I tried using the "forgot password", and it doesn't recognize my old username, or my email address. I don't mind using the new username, but it would be nice if it showed my original member date, and posting info.
Can you look that up and reset it?
seanbig
Kevin,Kevin Sjostrand wrote:Sean,
I will look this up tomorrow evening to see if I can't reset things.
Sean
Sean Big
Sean@BiggerRoom.net
Sean@BiggerRoom.net
