1st build; time to stop dillydallying!
RHayes
Re: 1st build; time to stop dillydallying!
Post by RHayes »
That setup should work well for you. I have yet to do anything beyond a simple binding channel so looking forward to your progress.
Is that $50 worth of hooks? Looks like it will work, but love to see it in action
BEJ
Post by BEJ »
Forgot how much they cost, did take them off the old set up though. Will get some pics of the binding process as it proceeds.
Bruce,
BEJ
Post by BEJ »
Some more progress, these 2 with bindings installed, binding must be the thing I hate the most building these things. Both have a 1st coat of Z poxie for some protection, seems like I have banged up past builds with little nicks and scratches.
Bruce,
BEJ
Post by BEJ »
Got some more work done on the bindings. Seems like no matter what I try I get small gaps at various points. Thought I would try this to clean these gaps and make room for some accents.
I used a 1/8" Dremel st bit to cut a channel that would take 7 veneer strips. I found some birch and walnut veneer packs at Woodcraft and cut a bunch of them for this and rosettes. I cut have cut a smaller inner rabbitt when I did the binding channel but still would have had gaps.
Cutting a channel this way you have to keep the guide rod always tight against the guitar body and any outward movement will muck it up. Had to sand the channel a little in a few places but overall it went well. Centering the bit on the gap seemed to leave a clean channel. Maybe a little too wide but this is a practice guitar for now, trying out new things. A few pics....
Bruce,
BEJ
Post by BEJ »
A few pics of the dremel set up a dimmer switch to lower speed....
BEJ
Post by BEJ »
Still chugging along, started finishing these 3, a little rough now but looking better after a few more coats....
