www.KitGuitarsForum.com
It is currently Mon Oct 22, 2018 12:38 am
Post new topic Reply to topic  [ 3 posts ]
Author Message
 Post subject: Changing neck type
PostPosted: Thu Feb 04, 2016 6:13 pm
Offline
Is there any reason why I couldn't turn a dovetail joint into a bolt on joint by putting bolts in through the neck block and not gluing the joint ??
Top
 Profile
 Post subject: Re: Changing neck type
PostPosted: Thu Feb 04, 2016 10:18 pm
Offline
you can but it will work against the dovetail
_________________
Top
 Profile
PostPosted: Fri Feb 05, 2016 10:22 pm
Offline
You might do better if you changed the dovetail to a straight mortise and tenon, but I'm not at all sure how one would go about doing that. I think you would have to fill in the cutout in the neck block in the body,fill in the sides of the dovetail with tapered wedge-shaped pieces, then cut the mortise and tendon.
I'm doing a mortise and tenon bolt-on neck on the Regal mandolin overhaul, but I wasn't starting with an existing dovetail joint and I'm carving a complete new neck.
_________________
Top
 Profile
Who is online
Jump to:
cron
