www.KitGuitarsForum.com
It is currently Thu Aug 16, 2018 1:47 pm
Post new topic Reply to topic  [ 4 posts ]
Author Message
PostPosted: Thu May 02, 2013 1:31 pm
Offline
I'm sure I am not the first one to think of this. I didn't want to take a chance cutting into the back while routing the binding channels so I made this temporary block and sanded it perfectly flush - it is held in by the neck bolt by virtue of a helicoil inserted into the block. Double sided tape would do just as well to hold it in place while routing. I'll rout and then remove it. Cheers!
_________________
David Delcambre
Picayune, MS
Top
 Profile
PostPosted: Thu May 02, 2013 1:50 pm
Offline
A suggestion. If your block is pre-cut for the mortise, don't cut away the sides until the binding, purfling has been installed. That way you don't have to worry about making a piece, etc. Been there, done that!
_________________
Sylvan Wells
Wells Guitars
Bay State Guitars
http://www.wellsguitars.com
Top
 Profile
PostPosted: Thu May 02, 2013 3:40 pm
Offline
Yep - making the block was precisely because I cut the wood away - what is is they say about necessity being the mother of invention? To quote someone on the forum, "It's not a mistake unless you can't fix it!" Thanks for the reply and have a good one.
_________________
David Delcambre
Picayune, MS
Top
 Profile
PostPosted: Sun Jun 30, 2013 9:21 am
Offline
I don't open the mortise until after binding. I have been told some folks don't open until after finishing and buff out, thus helping to prevent the opening from catching during buffing.
Tom
_________________
Top
 Profile
Who is online
Jump to:
cron
