www.KitGuitarsForum.com
It is currently Sat Oct 20, 2018 12:11 pm
Post new topic Reply to topic  [ 10 posts ]
Author Message
PostPosted: Wed Jun 20, 2012 6:02 pm
http://www.popularwoodworking.com/techn ... id=3341059
Top
PostPosted: Wed Jun 20, 2012 6:20 pm
Offline
good link
The best way is to check your techniques. Make sample glue ups and allow 5 days to cure out and then add weight till failure.
Toothing a joint was an old practice and really is useless.
_________________
Top
 Profile
PostPosted: Thu Jun 21, 2012 11:18 am
Offline
My understanding is the thinner the glue line the better. The glue would be less thick when glueing a smooth serface. Under magnification, even what we call a smooth sanded surface has a lot of pores.
_________________
Top
 Profile
PostPosted: Thu Jun 21, 2012 9:44 pm
Offline
the better the faces of the joint match the better the joint integrity
_________________
Top
 Profile
PostPosted: Wed Jan 15, 2014 9:13 pm
Offline
Hello John ,,question you and I being former machinists, do you think that the same grade finish usually ( finer is better) in most cases,,,, with wood is ok for gluing to units together with a similar finish rough to rough and fine to fine?
the new newbie Stephen
Top
 Profile
PostPosted: Wed Jan 15, 2014 9:16 pm
Offline
the better the surface for glue the better you are. Planed surfaces are more true than sanded surfaces so if you a sanding board be sure the as as true as possible.
_________________
Top
 Profile
PostPosted: Thu Jan 16, 2014 7:22 am
Offline
Thanks John
Great advice appreciate it .
Question is blade scraping considered a (sort of an efficient method) way of finishing a plane finish or not.Also is that a sort of burnishing? If so what are the pros and cons of such an effort (scraping)?
new newbie Stephen
Top
 Profile
PostPosted: Thu Jan 16, 2014 7:46 am
Offline
I use a jointer plane
a jointer
and sandpaper on a granite plate
hand scraping may not be accurate enough
you can test fit the joint and hold up to see light. I have a light table but use the window pane on my door. No light , no see joint add glue and go
_________________
Top
 Profile
PostPosted: Thu Jan 16, 2014 7:52 am
Offline
Hello John
These are terrific Ideas and I'll implement them as soon as I can ,,,appreciate it .The new newbie Stephen
Top
 Profile
PostPosted: Wed Mar 26, 2014 5:33 pm
Offline
And all other things being equal...the better the guitar...!!!
Tom
_________________
Top
 Profile
Who is online
Jump to:
cron
