www.KitGuitarsForum.com
It is currently Mon May 25, 2020 10:09 am
Post new topic Reply to topic  [ 2 posts ]
Author Message
 Post subject: top runout
PostPosted: Tue May 07, 2019 2:45 pm
Offline
Explaining runout is pretty easy if you have piece of wood that is perhaps a 2X4, but explaining what happens when light hits the two halves a perfectly book matched thin thin piece like a top is not so easy. Today I was driving through our rural landscape - Kent County MD, called the best agricultural land in the state - and I ran across something.
Thinking of the fibers of wood as straws, the perfect top is one that is both vertical grained AND the straws run full length without poking out of the surface anywhere - harder to do with thin wood
1) Here is last year's corn harvest and the remaining short stalks are tipped the direction the harvester was driving. Think of these as the fibers/straws that are inside the wood
2) Stepping back, we can see light and dark areas where the sun hits the flat side of the corn stalk or the end of each hollow tube
3) In the center you can see the color difference as a line where the harvester was going opposite directions
Just like the top where the light is hitting the face or the ends of the fibers in the top
Top
 Profile
 Post subject: Re: top runout
PostPosted: Wed May 08, 2019 6:21 am
Offline
Interesting analogy. This would be part of the reason for preferring tops coming from split billets as opposed to sawn billets? Ultimately the angle of fiber orientation & related fiber length would seem to be a critical strength consideration.
Top
 Profile
Who is online
Users browsing this forum: No registered users and 3 guests
Jump to:
cron
