www.KitGuitarsForum.com
It is currently Tue Oct 16, 2018 12:54 am
Post new topic Reply to topic  [ 11 posts ]  Go to page 1, 2  Next
Author Message
PostPosted: Fri Mar 10, 2017 1:32 am
Offline
Hi everyone,
I was wondering what grit to use when starting to wet sand. I choose to apply with a brush, which the directions say is possible. I put 3 coats on, then waited 24 hours, and sanded with 400, then applied another 3 coats. I was wondering which grit to start wet sanding after it dries a month? I think I'm happy with the results from the brush. I applied it very lightly and evenly over the body.
Thanks!
Top
 Profile
PostPosted: Fri Mar 10, 2017 7:39 am
Offline
we all may do things a little different but what I can tell you what I do
600 first to start cutting through the orange peel surface bumbs
when I am about 1/2 way through them I use 800
when I am just about bottomed I go to 1000
then once leveled I do 1500 2000
then buff and polish
after that I use Maquires swirl remover and 3m Hand glaze
_________________
Top
 Profile
PostPosted: Fri Mar 10, 2017 11:19 am
Offline
Take care with the final coat sanding. KTM-SV does not burn into the previous coat. If you sand through your final coat you will get witness lines. I found it hard to brush on KTM-SV and sand it without sanding through somewhere. Ultimately I got a spray gun and sprayed the final coat on a completely level surface. That coat took almost no sanding before I polished it out.
_________________
Top
 Profile
PostPosted: Fri Mar 10, 2017 4:40 pm
Offline
I was really hoping to avoid using a spray gun. Do you think it would be possible to user 400 very lightly to get the brush marks out before using 600?
Top
 Profile
PostPosted: Fri Mar 10, 2017 7:32 pm
Offline
I am not sure you have to wait a month with this finish it is not Nitro. I say this because then I could tell you sure try the 400, if you sand through the last coat apply another. If you are waiting a month in between though ... The witness line are visible as you are getting more to the polishing grades of paper.
Here is the writeup that I used when I used it.
http://www.newenglandluthiers.org/contents/Articles/Tips_Techniques_Tools/ktm-sv_an_overlooked_finish.html
_________________
Top
 Profile
PostPosted: Sat Mar 11, 2017 12:47 am
Offline
Hey John, thanks for the help. The link you gave me doesn't work. Do you think you could try again, or private message me it?
Top
 Profile
PostPosted: Sat Mar 11, 2017 10:02 am
Offline
whoops
_________________
Top
 Profile
PostPosted: Sat Mar 11, 2017 4:13 pm
Offline
Thanks John! I'm reading the final steps, and it says nothing about water. Am I wet sanding the guitar, or is it without water?
Top
 Profile
PostPosted: Sat Mar 11, 2017 4:50 pm
Offline
i did not use water, but i usally do not with water based finishes.
_________________
Top
 Profile
PostPosted: Mon Jun 11, 2018 5:47 pm
Offline
Johnparchem
I am a little worried about information that is 11 years old. I am sure that all of these finishes have undergone several changes in composition in this time. Have you recently used it with success? I am a month away from needing something and would like to try something new.
Top
 Profile
Who is online
Jump to:
cron
