Finish like my Seagull S6
limulus
Post by limulus »
Hi Guys,
I want to finish a guitar with the same type of finish as my Seagull S6. It is not a high gloss finish but really smooth and my hand moves so easily up and down the neck. The rest of the body can be glossy, but I really want the same finish on the neck. Is there a thread that references a similar finish. I did a couple of searches using seagull and finish but did not find anything. BTW, I'm new here.
B. Howard
Re: Finish like my Seagull S6
Post by B. Howard »
Try the term satin finish and you'll get more results. The process is basically the same a s a gloss finish except it is level sanded and has two flow coats of satin finish put on instead of being buffed.
limulus
Post by limulus »
Excellent and thanks! I also tried matte finish but sometimes my brain goes into idiot mode and it never occurred to me to search for satin. Thanks again.
limulus
Post by limulus »
Is there a recommended book or DVD with good info on satin finishes?
