www.KitGuitarsForum.com
It is currently Mon Nov 19, 2018 6:55 pm
Post new topic Reply to topic  [ 4 posts ]
Author Message
 Post subject: Polyurethane finish
PostPosted: Thu Jan 24, 2013 8:14 pm
Offline
I used to refinish wooden golf clubs and I sprayed them with deft polyurethane and they came out looking great. Just wondering if that would be good for finishing guitars.
Top
 Profile
 Post subject: Re: Polyurethane finish
PostPosted: Fri Jan 25, 2013 12:31 am
Offline
Refinishing a guitar?......as in spraying poly over lacquer? I don't think this would be ideal.
You can finish with polyurethane and it's a stable finish that is durable. The downside is it isn't as repairable as a lacquer finish so if the finish gets damaged, you might have to sand/remove the finish from the entire surface (whole top/back etc.) and re-spray a new finish where you could spray new lacquer on top of old lacquer and it will burn in.
_________________
Top
 Profile
PostPosted: Fri Jan 06, 2017 4:07 pm
Offline
Can I drop fill a polyurethane finish using nitro? I tried and it didn't turn out well at all. Can I drop fill polyurethane at all??
Top
 Profile
PostPosted: Sat Jan 07, 2017 9:15 am
Offline
Using nitro? not going to work very well as you have found. Typical drop fill for a poly finish is done with CA.
_________________
Top
 Profile
Who is online
Jump to:
