I don't know why the usual luthier supply houses don't have this.
https://www.internationalviolin.com/Sea ... ?word=shim
They're pieces of maple precisely cut to a certain angle, to make re-setting necks easier. I think they used to be sold in variations of degree angles... a half a degree, one degree, and (I think) a degree and a half. If you know what neck angle you need to achieve, it's a simple matter to use the proper shim.
Now they're selling them by "millimeters" but I'm sure that if you call them, they can give you the right product for your need. They've always had superlative customer service.
Shims for neck reset
Re: Shims for neck reset
Thank you for the link. I never know if I need a shim. If I do, I never know what I need, until I need it. I just keep a pack of veneers and I use scissors to cut one as I use it.
if anyone needs shims call me
when I started I used to make shims using my floor belt sander and I also ironed flat curls from my hand plane
for violin shims I had to make a few they can be a pain in the butt
