www.KitGuitarsForum.com
It is currently Fri Jul 20, 2018 2:18 pm
Post new topic Reply to topic  [ 6 posts ]
Author Message
 Post subject: Rosette
PostPosted: Sat Feb 04, 2017 5:09 pm
Offline
I'd like to remove and replace the rosette on a guitar I'm rebuilding. It's an old Yamaha 12-string. How do I go about that?
Top
 Profile
 Post subject: Re: Rosette
PostPosted: Sat Feb 04, 2017 6:06 pm
Online
carefully
what does the original rosette look like?
_________________
Top
 Profile
PostPosted: Sat Feb 04, 2017 7:12 pm
Offline
You can see what it looks like pretty well here-https://reverb.com/item/616660-yamaha-fg-230-red-label-nippon-gakki-natural?gclid=CIbPh4XI99ECFYMSgQod-qgMhQ&pla=1- mine doesn't have the pick guard on it.
Top
 Profile
PostPosted: Sat Feb 04, 2017 9:15 pm
Online
chances are you may cause damage.
you have to take the neck off first then try removing the rosette but taking out the middle of them first the hope you can pull the rest out without harm .
it isn't easy
_________________
Top
 Profile
PostPosted: Sun Feb 05, 2017 7:06 am
Offline
This may or may not be a good idea, but what I would probably do is make a plug for the sound hole with a 1/8" dia. center hole for the pivot pin of my router's circle cutter attachment. Then I would use the router to cut out the old rosette.
_________________
Top
 Profile
PostPosted: Wed Feb 08, 2017 6:37 am
Offline
I did this with a top I made, using the technique that you're going to use. First and foremost, anchor that top well. I made the plug, found center, and I thought I had the top anchored. As I routed, it started spinning on me when I was half way around. Also, the top under the rosette was so fragile that it came apart in a couple of places.
I had the advantage of a new, unbraced top. I can't imagine doing this with braces in place. I was able to do it, but it was touch and go.
Top
 Profile
Who is online
Jump to:
