www.KitGuitarsForum.com
It is currently Wed Jul 18, 2018 3:12 am
Post new topic Reply to topic  [ 6 posts ]
Author Message
PostPosted: Mon Oct 03, 2016 9:44 pm
Offline
A friend of mine bought an old Kay archtop guitar.
The nut cracked when he was bringing it up to tune (pretty cool headstock BTW).
Since he is a Dobro player, he'd like to replace it with a "high" nut so he can play
it lap style. The current nut is 1 5/8", but he'd like to widen it to 2" to get better string spacing.
One more thing: He tunes to open G, so there will be more string tension.
Questions:
1. Will the combination of a higher nut and higher string tension, put too much stress on the neck?
2. The wider 2" nut will extend out 3/16" from the neck, leaving it essentially unsupported. Is this a potential problem?
3. Another option is to replace it with a normal nut and Cap it with a "Fret extender" like this:
https://www.amazon.com/Grover-GP1103-Perfect-Guitar-Nut/dp/B00W7ZL4TM
Anyone have experience with these?
Thanks, It's been a year to too since posting. Nice to "see" you all again.
Mitch
Top
 Profile
PostPosted: Tue Oct 04, 2016 6:36 am
Offline
should be ok
_________________
Top
 Profile
PostPosted: Tue Oct 04, 2016 9:23 am
Offline
Quote:
The current nut is 1 5/8", but he'd like to widen it to 2" to get better string spacing ... The wider 2" nut will extend out 3/16" from the neck, leaving it essentially unsupported.
I am confused; how do the strings that are not over the fret board get fretted?
_________________
Top
 Profile
PostPosted: Tue Oct 04, 2016 8:10 pm
Offline
You don't!
The guitar is flat on your lap and you fret the strings from the top with a metal bar. You have to have a tall nut so the string won't touch the frets. The frets are just there for visual reference to help position the bar
https://m.youtube.com/watch?v=3dtPc3wNxOg
I need to do some research on this, but since you don't fret the string, I'm thinking that compensation at the bridge is not needed. Anyone have info on this?
Mitch
Top
 Profile
PostPosted: Tue Oct 04, 2016 9:39 pm
Offline
> should be ok
I should have also mentioned he uses heavy strings (0.016 -0.056), so combined with tuning up a step and a half (to G) I was concerned about the portion of the nut that is unsupported.
Is one nut material stronger than another?
What about starting with thicker nut stock?
Or am I over thinking this?
Mitch
Top
 Profile
PostPosted: Wed Oct 05, 2016 12:52 pm
Offline
Thanks for the clarification, I had always thought that the metal bar pushed the string down to the fretboard but I can NOW see just having it in contact with the strings is enough.
I obviously know nothing about a Dobro, but I follow your logic about lack of necessity for intonation.
_________________
Top
 Profile
Who is online
Jump to:
cron
