www.KitGuitarsForum.com
It is currently Mon Oct 22, 2018 1:49 pm
Post new topic Reply to topic  [ 4 posts ]
Author Message
 Post subject: Bridge String Question
PostPosted: Fri Sep 23, 2016 3:41 pm
Offline
Can a bridge that has 2 1/6" between the bass E and treble e, be replaced with a bridge with holes that are 1/16" wider (2 1/8")?
I know that the original holes should be filled and new holes drilled.
Top
 Profile
PostPosted: Fri Sep 23, 2016 4:06 pm
Offline
It really depends on the lay of the strings on the fretboard. I would suggest taking a piece of string and holding it at the low and high E string positions at the nut and see if you can manually move the "string" out to the spacing you want at the bridge. Obviously if the lay of the string is off the fretboard it is a no go! You also can usually be assured it is ok if the width of the 12-14th fret is the distance you want from e to e at the bridge.
_________________
Sylvan Wells
Wells Guitars
Bay State Guitars
http://www.wellsguitars.com
Top
 Profile
PostPosted: Fri Sep 23, 2016 4:27 pm
Offline
Agreed. Thank you.
Top
 Profile
PostPosted: Sat Sep 24, 2016 7:15 pm
Offline
if it is a martin yes but you always need to double check. One never knows what others have done.
_________________
Top
 Profile
Who is online
Jump to:
