www.KitGuitarsForum.com
It is currently Mon Oct 15, 2018 5:37 am
Post new topic Reply to topic  [ 6 posts ]
Author Message
PostPosted: Sat Jan 16, 2016 8:38 am
Offline
this one is a challenge as the heel joint failed The Tenon on the heel had to be redone. It was a tricky repair. I hope you can see how I figured out the angles to refit this joint. Lost of trial and error . I clamped this using a fret board block to hold all the parts straight. As you can see all the little pieces that I used to fit angles.
_________________
Top
 Profile
PostPosted: Sat Jan 23, 2016 6:39 pm
Offline
Was the piece that failed, originally a separate piece from the neck, or did you cut it to effect repair?
Top
 Profile
PostPosted: Sun Jan 24, 2016 11:32 am
Offline
the piece that failed was the miter joint itself. I had to steam the original lock tenon out. Then make a new one.
_________________
Top
 Profile
PostPosted: Sun Jan 24, 2016 11:38 am
Offline
http://www.maurysmusic.com/maury_s_blog ... ek_guitars
the joint pull was the lower link
check this out
_________________
Top
 Profile
PostPosted: Sun Jan 24, 2016 12:07 pm
Offline
That makes sense now. That's quite a repair.
Top
 Profile
PostPosted: Sun Jan 24, 2016 1:37 pm
Offline
Wow, great videos! The neck joint was quite a piece of Civil War Era work. I always wonder if those really old Martins were played by soldiers during the Civil War. I suppose I'd have a joint failure if I was over 150 years old. LOL The inlay work on Pearlzilla is beautiful. I'm hoping to reach that level of inlaying.
Top
 Profile
Who is online
Jump to:
